Fixed: ClearEdit: Disable Animations?
helloworld_dot_c
Post by helloworld_dot_c » 14 Aug 2006 02:41
Finally a worthy replacement for notepad!
Just one thing: I am certain you are proud of the animated menus and context-sensitive popup windows. I am an ignorant user who just happens to run everything with minimal delay/maximum speed and I would like to turn them off, but couldn't find an option for it. Is there an undocumented way? Do you consider adding such an option?
Thanks,
~helloworld.c
Re: ClearEdit: Disable Animations?
Post by Maël » 14 Aug 2006 15:07
helloworld_dot_c wrote:Finally a worthy replacement for notepad!
It just behaves like a normal Windows menu. I.e. if in your system settings you have enabled menu animation then you will see it, if it is disabled you shouldn't see any animation. Just like a standard Windows app.
helloworld_dot_c
Post by helloworld_dot_c » 15 Aug 2006 19:33
Positively not on my system (US-English Windows 2000, SP4, all patches). All animations are turned off and ClearEdit is the only program that still animates it's menus. No other application does it (including HxD).
Thanks,
~helloworld.c
Post by Maël » 15 Aug 2006 20:24
Hm, HxD and ClearEdit use the same components...
My dev version is more recent but only in German (will be released soon):
http://mh-nexus.de/downloads/ClearEdit.zip
Can you confirm it works with this version?
Thanks.
helloworld_dot_c
Post by helloworld_dot_c » 16 Aug 2006 02:48
Indeed, this version behaves normally, as expected. Funny, ain't it?
Thanks,
~helloworld.c
Post by Maël » 16 Aug 2006 06:19
Good, probably a fix in the toolbar component I didn't notice (toolbar component is mainly third party code).
