Fixed: "Abstract Error" when pressing "Next Array Item" with custom data type selected in the Data Inspector
Silberklinge
Post by Silberklinge »
Steps to reproduce:
  1. Build the following DLL and add it to the Plugins folder.
  2. Start up HxD and open a file.
  3. Select any byte in the file.
  4. In the data inspector window, click "Next Array Item".
I'm not sure whether this is a bug on my end due to poor implementation of my plugin, or a bug on the source program's end. Everything else seems to work fine.
Re: "Abstract Error" when pressing "Next Array Item" with custom data type selected in the Data Inspector
I replied to you about the plugin and some implementation issues by mail.
Regarding your bug report, indeed there is an error in HxD, I am investigating it right now.
Closed due to lack of feedback.
