Fixed: This seems like a bug in the latest version 2.4.0.0
Videogamer555
Post by Videogamer555 »
When I search for the number 500000 in 64bit integers (ctrl+R and then searching for the integer 500000 with Bitwidth being set to 64bit) it says "500000 is out of range representable with 64 bits.". Yet I know that 500000 is NOT too large of a number for 64bits. Not even close to being out of range.
In fact, it even says the number 1 is out of range, when I search for a 64bit integer with the value of 1!
Videogamer555
Re: This seems like a bug in the latest version 2.4.0.0
I hope this bug gets fixed soon. I need a way to search for 64bit integers, and currently that's broken.
Fixed in 2.5, which will be released soon when all the translations are ready.
For now you can get it here (without setup):
German:
https://mh-nexus.de/downloads/HxD25Deu.zip
English:
https://mh-nexus.de/downloads/HxD25Enu.zip
