Fixed: HxD: Custom CRC settings
Bryan
Post by Bryan » 19 Mar 2007 19:43
Is it intentional that the Initial value and Output XOR fields only accept 28 bits? I was hoping to set them both to FFFFFFFF.
Post by Maël » 20 Mar 2007 01:04
No, this is a bug. I fixed it in the development version (a beta is going to be out in about 1 or 2 weeks).
In the meanwhile you can use this workaround:
Change bitwidth from 32 to something else and the change it back to 32, then you can enter also values up to FFFFFFFF.
Post by Maël » 04 Apr 2007 13:57
Fixed in the actual beta (see download page)
Bryan
Post by Bryan » 04 Apr 2007 14:28
Great, thank you.
Where would I find the download page?
Post by Maël » 04 Apr 2007 15:20
Will take just a minute, sorry for posting before I uploaded.
Post by Maël » 04 Apr 2007 15:53
Okay, you can download it from here http://mh-nexus.de/hxd
I'll update the website later to add the change log, but the change log is also available in the ZIP-file.
Bryan
Post by Bryan » 04 Apr 2007 15:58
It's a beautiful thing, works perfectly.
Thank you very much.
