Fixed: HxD: Access violation when using file compare
Schtrudel
Post by Schtrudel » 15 Apr 2007 11:53
I got such error in File Compare:
at 004089CE in module HxD.exe . Read of Address 7FE80000
Furthermore, it's also weird that if I click somewhere in on the file, the whole compare is after that "out of sync"
Thanks
Schtrudel
Re: Error in File Compare
Post by Maël » 15 Apr 2007 12:13
Schtrudel wrote:I got such error in File Compare:
I could not reproduce it, please tell me the single steps. (Did you use the Windows context menu, opened the files directly, how many of them, in which order). Thanks.
Schtrudel wrote: Furthermore, it's also weird that if I click somewhere in on the file, the whole compare is after that "out of sync"
If "out of sync" means that when you click somewhere in the window, the compare continues where you clicked, then this is expected behavior. There will be a results window in future, so you can change the caret-positioning without it affecting the compare.
Schtrudel
Post by Schtrudel » 15 Apr 2007 13:38
To reproduce the problem, I opened to almost equal files (by regular Open icon on HxD). The files are exe files, one of them the "patched" version of the second; 2.7MB. I compared them, and I began moving along back and forth over the changes with F6 and Shift-F6. Most of the times on the "borders" (first and last change) I got the error, but was able to continue working on the files after closing the errors.
Post by Maël » 16 Apr 2007 01:12
(Note: I split the thread into two as the other bug was unrelated).
Could you perhaps send me those files? It would make it easier than trying to create files that cause the bug to appear.
You can send files to Image.
Post by Maël » 18 Apr 2007 17:26
Okay, this fixed the problem with the example files (you sent me), and it very likely should fix the problems with the files you used.
You can get the (German) development version that includes the fix here:
http://mh-nexus.de/downloads/HxD.zip
Could you please confirm it works with your "original" files, too?
Thanks,
Maël.
Schtrudel
Post by Schtrudel » 23 Apr 2007 15:51
Except that it's in german, it works ok ! :D
Thanks
Post by Maël » 23 Apr 2007 15:53
Fixed in development version.
Schtrudel
Post by Schtrudel » 23 Apr 2007 15:57
BTW, you put this development version at the place of the released one... Does this mean that 1.7.1.0 Beta German edition is a released version :lol:
Juuuust kidding
Post by Maël » 23 Apr 2007 16:00
I didn't, note that the filenames are different: HxD.zip, HxDBetade.zip and HxDde.zip. 8)
Schtrudel
Post by Schtrudel » 23 Apr 2007 16:15
:oops: My bad! :oops:
So, no development version in english? :roll:
Post by Maël » 23 Apr 2007 16:29
There will be a second beta after some other bugs are fixed.
Post by Maël » 08 Jun 2007 23:41
Fixed in version 1.7.1 beta
