Duplicate: HxD: Search
Bryan
Post by Bryan » 18 Apr 2007 19:47
Comment by Maël: This is a duplicate of http://forum.mh-nexus.de/viewtopic.php?t=153
I get the error: "Access violation at address 004BB82C in module HxD.exe. Read of address 00000008" whenever I search for anything, text or hex value.
testj
Post by testj » 18 Apr 2007 20:29
This also happens when using the search&replace function.
Post by Maël » 18 Apr 2007 20:51
This is probably the same as
It only happens if you opened the file per command line, Windows context menu or send to menu, but not when opening it per drag&drop or the file open dialog, right?
Bryan
Post by Bryan » 18 Apr 2007 20:54
You are correct. I just dragged a file into HxD and search works fine for all open files.
Thanks.
Post by Maël » 18 Apr 2007 21:11
Okay, I'll mark this bug report as duplicate then.
Though I wanted to fix all known bugs first, I'll release a new beta version as many people run into this bug.
Post by Maël » 21 Apr 2007 00:45
Maybe I should note that the new beta wasn't meant to come out immediately, but rather in a couple of weeks. (2-3)
Post by Maël » 08 Jun 2007 23:42
Fixed in version 1.7.1 beta
