Fixed: HxD: Can't open any file that has name with extention
ha944
Post by ha944 » 09 Jun 2008 23:14
Version 1.7.6.3 (install) running on Windows XP (SP2)
run HxD
File->open
Choose a file in the window that pops up and click OK
Got the message: "File not found"
Change the file name to not have an extention (i.e. "example.txt" to "example")
Opening the new file works fine!
Regards,
/Hossein
P.S. I used Cygwin to change the file names to not having an extention.
Re: HxD: Can't open any file that has name with extention
Post by Maël » 10 Jun 2008 19:04
Thanks for the report.
There have been similar bug reports due to addition of ADS (alternate data stream) support for the filename syntax in the open file window. So special filenames confuse the system. I'm working on a fix.
Just to be sure this is not an unrelated issue, could you check if other apps open this file fine (the file which didn't open correctly in HxD)?
ha944
Post by ha944 » 02 Jul 2008 20:18
Don't know if this is fixed already...just saw your question sorry for the late reply:
Yes the files can be opened fine with other apps.
Re: Fixed: HxD: Can't open any file that has name with extention
Post by Maël » 07 Aug 2008 18:37
Fixed in version 1.7.6.4 (will be published today)
Post by Maël » 08 Aug 2008 21:41
Ok, finally uploaded the new version (1.7.6.4).
