Fixed: HxD Fails to open a file
zespri
Post by zespri » 06 Aug 2008 00:32
- Create a directory with at least to files, or use already existing one. I'll use directory C:\HxDTest with files OneFile.Txt and AnotherFile.Txt
- Copy C:\HxDTest\OneFile.Txt in clipboard
- Open HxD
- Click the "Open" button on the toolbar
- Paste the path that is in clipboard into the input field of the Open dialog and press 'Open'
- Click the "Open" button on the toolbar. The open dialog will show, displaying the D:\HxDTest\ directory.
- Double - click "AnotherFile.txt". The "Open" dialog will disappear but the file won't open.
Re: HxD Fails to open a file
Post by Maël » 06 Aug 2008 16:02
I'm going to upload a minor update today or tomorrow that should fix all the issues related to the open dialog.
I'll post a notice here again. Could you then test please if it works?
zespri
Post by zespri » 06 Aug 2008 23:22
Sure, just let us know when it's ready =)
Re: Fixed: HxD Fails to open a file
Post by Maël » 07 Aug 2008 18:39
Should be fixed in version 1.7.6.4 (will be published today)
Post by Maël » 08 Aug 2008 21:41
Ok, finally uploaded the new version (1.7.6.4).
zespri
Post by zespri » 09 Aug 2008 08:30
This has fixed the issue. Thank you.
