Fixed: Assertion failure when cancelling file compare
Hlv
Post by Hlv »
v 1.7.7.0, Windows 7 64-bit
Open two large identical files.
Start file compare.
Click "Cancel".
"Assertion fehlges (D:\Quellen\Neu\Hexeditor\Compare.pas, line 167)"
Thanks for HxD, it's great!
623
Re: Assertion failure when cancelling file compare
Post by 623 »
same thing
not only identical, these 2 files was only the same size, large and not identical
v 1.7.7.0 win x32
not critical, yet dissapointing
yup, the best HEX editor i know
I cannot reproduce this problem. Please specify the exact file size where this happens (for two identical files). Thanks.
Or do you press the cancel button?
anon
Post by anon »
I could reproduce this problem. Two identical files, file size = 40.000.000.000 bytes, compare operation, cancel --> assertion.
Fixed already in 2012 in SVN revision 522.
But the current 2.0 RC makes the fix "public".
