Fixed: HxD lists contents of one folder which belong to another
AlwaysFun
Post by AlwaysFun » 18 Sep 2014 15:07
When I try to open a file in C:\Windows\System32\drivers\ , I don't see the files for that folder displayed. The files which are displayed are from C:\Windows\SysWOW64\drivers\. When I try to open a file in C:\Windows\SysWOW64\drivers\, I see the same files. In other words, files in C:\Windows\System32\drivers\ are inaccessible.
This appears to be an HxD bug because Windows Explorer lists the files correctly, as does "Everything" from voidtools.com. Also, I can switch hard drives on my computer and boot to a different hard drive. Then I can see the formerly inaccessible files because Windows has now reassigned the drive letter, in my case it becomes U:\Windows\System32\drivers\ . When I use this second hard drive as a boot drive, the files on it in C:\Windows\SysWOW64\drivers\ are incorrectly listed under C:\Windows\System32\drivers\, repeating the same type of error made when the first hard drive was the boot drive.
My operating system is Windows 7 Professional, 64 bit. The version of HxD I have is 1.7.7.0.
Here is a possible cause. Quoting from http://www.samlogic.net/articles/32-64- ... swow64.htm :
But what about 32-bit applications that have the system path hard coded and is running in a 64-bit Windows? How can they find the new SysWOW64 folder without changes in the program code, you might think. The answer is that the emulator redirects calls to System32 folder to the SysWOW64 folder transparently so even if the folder is hard coded to the System32 folder (like C:\Windows\System32), the emulator will make sure that the SysWOW64 folder is used instead. So same source code, that contains a path with the System32 folder included, can be compiled to both 32-bit and 64-bit program code without any changes.
Re: HxD lists contents of one folder which belong to another
Post by Maël » 22 Sep 2014 00:57
Yes, for 32 bit programs there is a redirection of system directories under 64 bit versions of Windows. It can be deactivated, but is not advisable as parts of the system may rely on it (for example DLLs that get loaded by Explorer extension as in the open file dialog).
http://blogs.msdn.com/b/oldnewthing/arc ... 04021.aspx
In other words, it may cause issues for libraries or programs beyond HxD's control.
But a 64 bit version of HxD will be available, which will fix this automatically by being 64 bit.
Post by Maël » 24 Oct 2017 19:55
Since HxD 2.0 is available since a while (as RC), this bug can be closed, as mentioned above.
http://mh-nexus.de/downloads/HxDSetup.zip
