Not a bug: Wrong language showing in user interface
Darko8
Post by Darko8 » 05 Apr 2015 15:36
All menu text is completely scrambled. I'm using 64bit Win8.1 enterprise with 32GB RAM. Same thing was seen in setup (so no real recognisable text).
See screenshot below.
Regards, Darko
Re: Win8.1 64bit bug (unicode?)
Post by Maël » 08 Apr 2015 15:54
What language version did you download?
This is most likely a version from another non-latin script, such as Chinese or Russian, etc..
You need to have the Windows locale settings be set to that script or download the proper language version of HxD.
Darko8
Post by Darko8 » 14 Apr 2015 11:28
Thank you, you were right.
Somehow I had wrong language installed. Funny thing is, I took this installation from my other computer where I have HxD installed (English lng) so it was probably installed from different setup on that computer...
Regards, Darko
Post by Maël » 14 Apr 2015 16:47
Thanks for reporting back and I am glad you could fix it.
I'll close the report then.
