Cannot reproduce: S37 export error
jimt
Post by jimt »
Was exporting a very large file to S37 format and discovered that the checksum seems to increment by 1 after a while:
S3150100300000000000000000000000000000000000BA
S3150100301000000000000000000000000000000000AA
S31501003020000000000000000000000000000000009A
S31501003030000000000000000000000000000000008A
S31501003040000000000000000000000000000000007A
As you can see from the address this is after a million lines or so.
Re: S37 export error
I tried it with the latest version:
When I export the complete file contained in the attachment (s37exporttest.bin), I get the results as expected, for the last lines.
For example:
S315010030400000000000000000000000000000000079
Verifying the calculation by hand, indeed the checksum 7A would be wrong (as you pointed out) and 79 would be correct.
So far all seems fine.
Do you see the same behavior?
If not, can you provide the steps you performed? (And please tell me the OS version, if you run 32bit or 64bit HxD, and the language of HxD you use).
s37exporttest.zip
(19.41 KiB) Downloaded 227 times
