Cannot reproduce: HxD V2.1 The company name cannot be empty
vincentlu
Post by vincentlu »
Hi ! Sir,
I got error message belw,
The company name cannot be empty.
Thank you.
Re: HxD V2.1 The company name cannot be empty
Which language of HxD are you using, and which edition (portable or installable) and what Windows version/language?
Also when does it happen, at startup or end or when?
Thanks.
vincentlu
Post by vincentlu »
Hi ! Sir,
language of HxD : English
which edition : Portable
Windows version/language : Windows 7 X64 / Traditional Chinese
when does it happen : Startup
Thank you.
I tried it under Windows 10 x64 Simplified Chinese, and I couldn't reproduce it.
I'll add logging to HxD so we can find out what happens. Have you tried moving HxDx64.exe to a new folder so that the settings folder is recreated? Does it still show this error at startup?
vincentlu
Post by vincentlu »
Hi ! Sir,
I try again,it is OK.
I have no ideas about this error.
The messages for what ?
The product name cannot be empty
Thank you.
vincentlu wrote: 30 Sep 2018 21:58 I try again,it is OK.
Do you mean you don't see the error anymore?
vincentlu
Post by vincentlu »
Yes.
It works very well.
So, I'll close it as "cannot reproduce" since we both seem to not be able to trigger this behavior.
Re: Cannot reproduce: HxD V2.1 The company name cannot be empty
I had another user report a similar error: https://forum.mh-nexus.de/viewtopic.php?f=3&t=1156
Did you use Sandboxie maybe, or something similar that hooks into operating system functions?
