Option to Display Decoded Text First or Hide Hex Column
bakes
Post by bakes »
I love the new version of HxD! Thank you!
I usually use HxD to view files so having an option to show the Decoded Text on the left side, before the hex values would be very helpful. Alternatively, or in addition to, being able to hide the hex values would be useful too. It would save me from having to do a lot of extra scrolling.
Re: Option to Display Decoded Text First or Hide Hex Column
There is an option under the menu "View|Visible colums" to only show the text column.
bakes
Post by bakes »
Can this option be saved so it's remembered when I close and re-open HxD?
