Won't Do: ClearEdit: Some features request
Nelson
Post by Nelson » 26 Aug 2006 07:41
Hi, I've tried the latest version and it is good.
I'd like to request some features and hope you can consider them.
  1. Show line numbers.
  2. Since there is a Procedure List function, maybe you can dock the window to the right side. Thus, users can easily navigate through the codes.
  3. Indent guideline. Show a vertical dotted line when indent, then programmer can easily realize the hierarchy of the code. Like Notepad++
  4. Automatically enable OEM-charset when opening .nfo files.
  5. Brace highlighting. When I move cursor to { , the relative } will be highlighted, and vice versa.
  6. Current line highlighting.
Again, thanks for your effort. :D
Re: ClearEdit: Some features request
Post by Maël » 26 Aug 2006 15:16
Nelson wrote:Automatically enable OEM-charset when opening .nfo files.
This should happen for all files that are detected as DOS/OEM.
Be sure to enable the DOS/OEM-option in "editor options".
For the rest:
Sorry, but I really want to keep ClearEdit simple. I don't want to extend it to a programming editor, it is mainly a notepad replacement.
There are probably other programs that will suit your needs better.
