plug-in architecture for structures
MinusMyX
Post by MinusMyX »
Some sort of plug-in architecture (could be COM, or could be .Net), to add user menu and interpretation code. I'm specifically thinking of interpreting master boot record, or FAT32 records, etc. Then, instead of showing raw bytes, user could show the sector in a specific format.
Re: plug-in architecture
You are probably aware of the plugin architecture that exists so far?
I am working on a data inspector extension right now, so that you can define structures using a simple language, and it will display the decoded data in a kind of tree-like view.
Once that is out, we can see what makes sense as plugin, and what is better suited as extension of this language.
Stay tuned, it's going to be pretty powerful.
