Support High-DPI GDI Rendering
imadewins
Post by imadewins »
For the most part, HxD renders with GDI HDP rendering properly, but some of the (custom) rendering of the hex view does not and looks blurry when enabled, a few glitches happen as well.
To enable this for HxD Go to the Compatibility tab then set the setting to:
Set display scale anything other than 100% and it will have bugs.
Should be a simple fix.
Re: Support High-DPI GDI Rendering
It needs a new set of icons, for which I need a new license.
Delphi's VCL has several bugs for high DPI, new versions are 2000€ (Delphi Professional is the cheapest edition supporting the features that HxD needs).
It's more than a simple fix ;)
pleasereset
Post by pleasereset »
In which language is HxD written?
Wonder if I can help in any way. The lack of HiDPI support will only be a growing pain moving forward as low DPI monitors are increasingly being phased out.
It's written in Delphi. The issue is the price of the current version, and the need for a new set of icons (for which I have certain requirements), and some of which I made myself, and would need to remake in higher res.
europa
HxD is blury on Windows 10 with scala 125 %
Post by europa »
In Windows settings -> Screen -> "Scala and setup" I have 125 % zoom on the entire screen.
This makes HxD blury.
Screenshot: https://courses.frindex.net/computer_st ... fx/hxd.jpg
bpw
HxD high-DPI capable version
Post by bpw »
I've been using HxD for quite a while. It is a great tool that I would not want to miss in my toolbox.
However, HxD does not appear to be high-DPI enabled for use with high DPI monitors under Windows 10.
With high-DPI monitors becoming more and more common, is high DPI support in HxD planned?
Thanks
Bernhard
Hi, please see the comments above.
