Close current child window when Alt+F4 is pressed, NOT entire program
vertigo
Post by vertigo »
If a child window, e.g. Statistics or the contents of a file, is opened, and Alt+F4 is pressed to close it, the entire HxD program is closed. This is unexpected and can result in lost work. The shortcut should close only the currently active window, at least optionally.
Re: Close current child window when Alt+F4 is pressed, NOT entire program
The standard in Windows is to use Ctrl+F4 to close MDI windows. Additionally HxD supports Ctrl+W.
