Hot-key to toggle between two files
Would it be possible to add an Alt-Fn hotkey to toggle between the last two selected files? This would make it easier to visually identify the differences between these files. Currently I need to keep moving the mouse and clicking each of the tabs.
Re: Hot-key to toggle between two files
You can already do it using Ctrl+Tab and Ctrl+Shift+Tab. If you have only two files open, Ctrl+Tab will be just fine (it cycles through the tabs, so second press will just take you to where you started)
