Done: ClearEdit: place cursor AFTER timestamp in .LOG file
adotka
Post by adotka » 28 Apr 2008 15:25
It would be better to position the cursor on the next line after created timestamp, when opening the file, beginning, with .LOG
Currently ClearEdit places cursor at the beginning of the file
Post by Maël » 02 May 2008 21:19
You are right, that is the default behavior of Notepad, too.
Will be fixed in next minor update.
Re: ClearEdit: position the cursor AFTER timestamp in .LOG file
Post by Maël » 05 Aug 2008 20:19
ClearEdit is only used internally now, no future version will be published.
