Enhance displacement feature of goto dialog
RollingJ
Post by RollingJ » 17 Sep 2008 11:47
Great program, really useable.
I'd like to be able to specify a negative displacement in the goto dialog "Offset" field so that I can jump backwards from the current location.
Thanks in advance.
Cheers, Peter.
Re: Enhance displacement feature of goto dialog
Post by Maël » 21 Sep 2008 18:23
Ok, on TODO-list.
Homer
Goto offset backwards
Post by Homer » 24 Oct 2017 10:52
I want to go up n bytes relative to the current position. But I can't.
  • There is no "actual offset (backwards)" radio button, so I had to select "actual offset".
  • It is not possible to enter a minus before the hex offset n.
  • The minus in front of the decimal offset n is rejected.
