Done: Out of memory error
TorPedoCXC
Post by TorPedoCXC »
Hi.
I am trying to edit a 4 GB large text file (replacing). The speed of your program is just great, but it only runs as a 32bit process and stops working with an out of memory error when reaching half of the file (the Taskmanager shows 2 GB RAM utilization).
Is it possible to compile a 64bit version? As I understand searching and replacing needs to store the whole file in memory. That will be a problem with a 32bit program, because AFAIK they can only obtain a maximum of 2GB RAM.
Daniel
TorPedoCXC
Re: Out of memory error
Will this problem be adressed in the future? It's a bit cumbersome to replace only half of the file, save, and then continue to replace the other half.
It will be addressed. But it's not merely a compile for a 64 bit version, so it's not something in the near future.
Still I wonder why there is such a huge memory consumption. How many bytes get replaced?
Can you tell me the approximate number of replaces and the length of the search and replace pattern?
TorPedoCXC
I am replacing the text-string "MinimumYield" with "MY". The program starts replacing and crashes with an OOM-error when reaching the 2 GB limit. I also tested this with a smaller file (3 GB), which also crashed at 3 quarters of the full progress bar. There are a total of about 15.000.000 occurences of this text string in the file. Could it be that the undo-function takes up a lot of RAM? Would it help if you've got access to the file I was working on?
Yeah, the undo data + the data structures managing the edits of the file at many places is using up quite some space + memory fragmentation and it's going to be over the limit.
I'll keep that in mind for optimization, but 64-bit support is probably closer. Also if you would have an example file it would help, though it's not strictly necessary.
TorPedoCXC
I tried to edit the file ProsperDataExport.xml which is included in this Zip-File: https://services.prosper.com/DataExport ... rt_xml.zip
I managed to edit it by replacing only half of it, saving, reloading and continuing the replacing. Luckily this was a one time task.
Just in case this is still relevant.
HxD is available in 64 bit now.
