Done: Show its decimal value for a selected hex datum
cloudrack
Post by cloudrack » 22 Sep 2012 15:47
First thanks Maël Hörz very much for such an userful Hex editor tool. It is very helpful in my work.
I know HxD by searching the internet, and I compare several known free hex editors. Finally I find I like Hxd best for its simple but practical style.
I request a kind of feature: when user select a hex datum, its corresponding decimal value can be displayed at the same time.
I think it is like a certain data inspector/convertor/interpretor, it can be optional in the menu item, and can be a floating window in the right region of display window.
Re: Show its decimal value for a selected hex datum
Post by Maël » 23 Sep 2012 17:48
There is a data inspector in the making, it will be released in the next version. Not more than 6 months from now.
cloudrack
Post by cloudrack » 24 Sep 2012 14:20
Thank you for your response! I am expected for it :)
Post by Maël » 06 Feb 2019 14:40
HxD 2.0 and higher implements a data inspector.
