Delete bytes
mcb
Delete bytes
Post by mcb » 11 Oct 2013 16:18
I'd like to have an option to Delete bytes, like there is one to Insert bytes.
Ideally it would allow you to specify x bytes also from the beginning or the end of the file, and with an option to apply to all open files (similar to the request filed under Search & Replace for All files).
