Split/merge odd/even
mcb
Post by mcb » 09 Jul 2015 01:27
I often work with ROMs and EPROMs where the data is split in odd/even bytes across two chips. Depending on whether I work with dumps or whether I need to generate the data, I need to merge or split.
Extras/File tools already has Concatenate... and Split... tools. It would be great if this could be enhanced with additional options to:
- Merge odd/even files into a new file
- Split file into odd/even files
Options that come to mind:
- Hi-endian/low-endian (odd/even vs. even/odd)
- Split/merge unit size (byte, word, etc.)
