Solved: Copy as > Editor View (HEX only)
h3k
Post by h3k » 06 Nov 2016 18:19
Hi!
I already searched the forums but I didn't find this particular request.
What I'd need is to copy the editor view without the offsets.
In "View > Visible Columns" it's possible to hide the text but how do I get rid of the offsets?
Re: Copy as > Editor View (HEX only)
Post by Maël » 08 Nov 2016 17:46
If you select the portion you want and make sure the hex column is focused (use TAB to switch between text and hex), then copy to clipboard (ctrl+c as usual), do you get what you want?
h3k
Post by h3k » 08 Nov 2016 23:16
Not exactly, because I'd also need the new line characters like in "Copy as editor view".
Post by Maël » 06 Feb 2019 15:34
I guess the easiest is to paste the result in a text editor and use Alt+Cursor keys or Alt+Mouse selection to select the offset row and delete it.
h3k
Post by h3k » 06 Feb 2019 16:05
Rather brilliant! Why didn't I think of that? :D
Vielen Dank!!
