Request: HXD compare. - select all sources as in tools too
minsik
Post by minsik » 17 Jul 2017 03:39
HI, thanks for the excellent HXD.exe editor/viewer. It is a swiss army knife always.
In the new 2.0 compare function can we have select drives or things that are in the tools section please?
ie this would be an excellent way to load two HDD and compare boot sectors,(if possible).
I find currently I have to load the two physical HDD's, then select a few sectors, then export this information into files, then load these in my notepad++ editor, and then compare the files. To select other areas needs the process repeated all over again. Any changes also requires this process to continue.
