How can i reset options.
rgnt
Post by rgnt »
how can i reset my options? I tried to search for config file, but i haven't found it. I tried reinstall, didn't work.
Re: How can i reset options.
The config file is under %AppData%\Mael Horz\HxD Hex Editor .
Just delete the ini file, not the lang file, to reset your options.
For the portable, it is in the Settings sub-directory next to the HxD.exe.
P.S.: Config files are not deleted by setup-programs by default, since they are stored on a per-user basis, and the setup usually can't list/access all users. So for consistency, config files are usually kept for all users, "accessible" or not.
