HxD: Copy without spaces
pantex
Post by pantex »
I have a quite simple problem, but I'm unable to finde the solution:
I want to copy a part of the hex-block to another program. The point is that I don't want the spaces between the values (often they are very useful, but not in this case).
This isn't possible directly.
But you can copy the hex-block, paste it into a text editor and do a replace all with space as search pattern and nothing as replace pattern.
Notepad/Windows-Editor should be able to do this replace.
