GAME file
Tcoo
GAME file
Post by Tcoo » 18 Jun 2007 09:05
i'm trying to change something in a game file can anyone help me,i cant code at all
my msn email is:Brollythesaiyan@msn.com
Post by Maël » 20 Jun 2007 17:00
It very much depends on what game you want to change. Generally though, you don't need to code.
If for example you have a certain amount of money in your save-game, say 1000, and want to have 20000, then you could try the replace-function of HxD:
In HxD open the save-game, choose the menu "Search|Replace", enter 1000 in the first text box and 20000 in the second. As datatype choose integer number. Then press OK.
The key to succeed is to save the game at a moment you know the amount of money exactly.
If however there are more places in the save game that contain the number 1000, this could not work as you first have to find out which of the occurrences in the save-game is the right one.
For further details you should search the web, for things like save-game and the name of your game.
Hope this helps a little.
