Bit array pasting
Felius
Bit array pasting
Post by Felius » 14 Dec 2008 00:57
Sorry if this is a stupid question. :oops:
Anyway, basically what I have is some bytes written in bit form. (I mean, like "1010111"). I'd like to know if there is a function or some way to paste them directly into the program so it interprets it correctly. This is because although I, strictly speaking, can convert the binary array to hexadecimal one by one, it's a very cumbersome and boring job.
Thanks for the time you have spent on me by reading this topic,
Felius
Re: Bit array pasting
Post by Maël » 15 Dec 2008 20:02
Felius wrote:I'd like to know if there is a function or some way to paste them directly into the program so it interprets it correctly.
Currently this is only possible, like you mentioned, by translating it from binary to hexadecimal form. (for example using Windows-Calculator).
The next version will feature a data inspector with several interpretations (including decimal and binary), so this should become easier.
