Right Click menu
Right Click menu
I installed HxD onto my new computer, but on this computer the right click menu options of "Open with HxD" and "Open with HxD (read only)" are missing. Is there a way to get them to appear? The computer uses Windows 7 Professional 64 bit.
Re: Right Click menu
You have to run HxD as administrator and then set the option for adding HxD to the explorer context menu. (see Extras|Options). Afterwards you can run HxD as non-administrator again.KageNoOni wrote:I installed HxD onto my new computer, but on this computer the right click menu options of "Open with HxD" and "Open with HxD (read only)" are missing. Is there a way to get them to appear? The computer uses Windows 7 Professional 64 bit.
Thanks for the reply, that did indeed fix it.
