Hello, I'm trying out HxD and I like it so far but I can't get it added to Explorer's context menu.
When I select "Add HxD to Explorer's context-menu" it fails with a "Failed to set data for EditFlags" message. I'm using Windows 7 Pro x64 SP1.
Could someone clue me in?
Trouble with context-menu option
Re: Trouble with context-menu option
Run HxD as administrator once to add it to the context menu. Next time you can run it as normal user again.
Thanks. It worked of course.
