I load a 4 GB disk/chip image.
I select the statistics analysis.
It scans for a minute, and then
presents no result nor saves any file.
Am I missing something else I am supposed to do to see the results?
1.7.7.0
Steve
Display of statistcs scan results
Re: Display of statistcs scan results
It should display a new tab/window with a graph showing the frequency distribution of every byte from 0..255.
Could you send a screenshot?
I found the problem. My data had a high count outlier. I discovered a 'hide maximum' option after a random right click. That made the graph visible. The two screen shots attached show without and with hide maximum.
Thanks for the feedback.
Thanks for replying (I didn't see any attached screenshots but I know what you mean).
Maybe I'll find a way to make this more obvious.
