How do I change the File Compare font color?
Fizbin
Post by Fizbin » 09 Jun 2014 05:22
It shows up as bolded black, but I find it difficult to see. Is there a way to change it? I can see the options for the other elements but not this one.
Thanks.
Re: How do I change the File Compare font color?
Post by Maël » 12 Jun 2014 21:48
There is actually no special color for file compare. The currently compared bytes are simply selected. So if this is hard to see, you have to change the selection color/font settings in the options.
mvekaz
Post by mvekaz » 04 Jan 2019 15:03
I think that is much better option for compare file to change background color for all different bytes.
Post by Maël » 04 Jan 2019 19:42
There is a feature request for this, the selection is independent of that.
