XN Resource Editor
adem0x
XN Resource Editor
Post by adem0x »
Hi Maël,
Are the sources available anywhere else --and is there any progress on the 64-bit front?
Thank you.
Re: XN Resource Editor
I don't work on XN Resource Editor anymore, that's why I sent the ZIP by mail. Sending a link here would suggest I would maintain it, but ofc you can/are encouraged to publish it on any code sharing website (or your own), it's still open source.
