saving
pctopgs
saving
Post by pctopgs » 14 Jul 2006 04:30
yo
im new and new to hex editing too.Im havin trouble saving things.when i save,it saves as a 'file' type.how do i save it in exe?
pctopgs
Post by pctopgs » 14 Jul 2006 04:41
also, can i save it as a project, like a 'hxd document'?
Post by Maël » 15 Jul 2006 17:36
There are no special file types for a hex-editor, it considers every file just as raw data, i.e. you see every byte, there is no special interpretation, opposed to e.g. a image editor.
To save a file specify the full name, if you want to save it as exe just append .exe to the filename. Naturally the content of the file must be a valid executable, appending .exe is not enough.
There is no special 'hxd document', choose any name you see fit. Some examples: file.raw, file.bin, file.dat
