I've got a 15 gb usb filled with 2 partitions (5gb linux os, 10 gb ext4 partition). I ran HxD as admin, picked my usb from the devices list, uncheck the read-only option, wrote my changes, pressed ctrl-s, and boom a pop-up "Access denied" shows up.
I can write my usb using windows (adding text files, folders), edit partitions via device management.
I'm running win 10 (not sure if that helps)
P.S: i've tried turning it on and off, doesn't help
