RNG question
gduta
RNG question
Post by gduta »
HxD is fantastic in the version 2.1 !!!! Thanks and congratulations!
One quick question. In the "Fill Selection" with "Random Bytes", what is the RNG method or API used by HxD ?
Re: RNG question
It's from the Delphi runtime library:
// Random integer, implemented as a deterministic linear congruential generator
// with 134775813 as a and 1 as c.
function Random(const ARange: Integer): Integer;
var
  Temp: Longint;
begin
  Temp := RandSeed * $08088405 + 1;
  RandSeed := Temp;
  Result := (UInt64(Cardinal(ARange)) * UInt64(Cardinal(Temp))) shr 32;
end;
RandSeed is initialized with time-like values:
procedure Randomize;
var
  Counter: Int64;
begin
  if QueryPerformanceCounter(Counter) then
    RandSeed := Counter
  else
    RandSeed := GetTickCount;
end;
gduta
Re: RNG question
Post by gduta »
Thanks!
