Switch values to maintain file size
CoolFrogDude
Post by CoolFrogDude »
As the title says, I want to switch two values of different sizes in order to maintain file size.
My current method is (A being smaller, and Bbeing larger)
1. A -> unused string of same size
2. B -> A
3. Unused string -> B
The file size at the end of the process is the same but anticheet seems to detect that as a change
Re: Switch values to maintain file size
It could be it uses a checksum or hash to validate that the file was not changed.
CoolFrogDude
Thank you Maël, I have been able to change values before e.g A -> B and it seems to be fine jus tnot if I temporarily change the file size
