Fixed: Garbadge display on more then 32 bytes per row
smeezekitty
Post by smeezekitty »
i attached a picture::::
smeezekitty
Re: Garbadge display on more then 32 bytes per row
Hello Mael,
my os is windows vista SP 1
its regardless of the graphics driver or file loaded it looks distorded
i think u will agree from da pictre above
What version of HxD are you using?
smeezekitty
1.7.6
The newest version which is out since April is 1.7.7. This version should have this bug fixed.
smeezekitty
its fine in the new version
Please, check the new version before posting a bug in future. It reduces the time I spend trying to reproduce a bug.
smeezekitty
Re: Fixed: Garbadge display on more then 32 bytes per row
it also fixed the ext2 stream read error
