I use Vista 64 bit with UAC activated (but run HxD as admin). Maybe that makes the difference.
Anyway there is such a limitation for hard disks: http://support.microsoft.com/kb/942448
Fixed: HxD: Access denied while editing floppy directly
Re: HxD: Access denied while editing floppy directly
The bugs back!
All of the sudden i cannot access sectors anymore.
It should never have been fixed. Probably it was a setting in your system, or it depends on which Vista version you used.
Anyway, a fix is underway and will be available in the next release.
Its still a problem.
For a similar thread, see here: viewtopic.php?f=3&t=438
HxD 2.0 RC implements automatic unmounting and write locking of disks if possible, which should solve most of the access denied problems transparently.
You do not need to do anything special, simply edit a drive and save.
As mentioned earlier in this thread, since Windows Vista hard disk access is enforced in a more strict way, so it is impossible to fix this in general.
But especially for removable disks/thumb drives, it should work in many cases now.
If access still is denied, using a boot cd/DVD or a preinstall environment like WinPE will allow HxD to edit any disk, since those environments do not hinder any writes.
So, if you had problems like this in the past, try out HxD 2.0 RC.
