HxD is a great program, I like it so much!
"clear" is a shortcut of using "fill selection with 0x00", it is more convinent to use. Please consider this feature again.Maël wrote:clear can be done using "fill selection", I will not add an extra menu item for this
Yes, I agree that it isn't a priority, but this feature can be used to indicate HxD is a super hex editor...display data as hex,decimal,octal and binary
Maybe sometime in the future but this isn't a priority.
paste from
copy to
Why not use the normal copy and paste?
I want to avoid to implement everything that might be good or just makes the feature list longer.fromnuaa wrote:Yes, I agree that it isn't a priority, but this feature can be used to indicate HxD is a super hex editor...display data as hex,decimal,octal and binary
Maybe sometime in the future but this isn't a priority.![]()
How often do you use them? Do you often want to paste an entire file?"paste from" and "copy to" can be done using normal copy and paste, but they are more convinent, they are shortcuts users ofter used, please consider to include them in next version. Smile
