some excelent features
ice.blade
Post by ice.blade »
I like HxD its simple clear and fast hex editor :) but I miss some spec
1. memory function on find window... when I restart app I must select datatype to HEX again...
2. when I press F3 and next string cant found pls make research again button or basic repeat search function when press F3 again over cant found popup window (example: when press F3 again cant find window close and show next string from top)...
3. when I press history back pls make history next function
4. toolbar with history back and next button pls pls
5. when I compare hex files pls make colored diference
6. when some offset diferences are together pls group it to one diference... example 00 11 22 33 44 55 66 77 88 99..... (00 - first diference, 33 44 55 - second diference, 88 99 - third diference etc)
7. toolbar with arrow - next and back difference
8. in compare mode pls lock scrolling both of window, when I scroll one pls make scroll both of window together
9. when exit one of compare window pls ask really and after turn off compare function (lock scroll + color highlighting)
10. make show row grid line to view menu
11. left offsets without first zeros... example I open file with FFFF, first line shows four zeros too... 0000-FFFF, when i open file with FF pls left ofset shows only 00-FF
12. pls make 0123456789ABCDEF up to text column
13. two colored hex column... example:
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
64 02 26 05 DC 0B B8 17 70 2E E0 04 00 03 06 00
0D 08 06 05 00 03 00 26 58 7D 02 1A 0F 03 00 08
07 0A 64 64 8C 04 00 00 00 00 C8 01 90 02 58 04
C8 00 FA 01 2C 01 2C 03 00 03 08 14 50 64 C8 00
