custom bytes per row
Bluerose555
Post by Bluerose555 » 23 Mar 2017 10:01
Just wondering if there is a feature which allows users to use custom bytes per row?
I often deal with data strings that are in between 16 and 24 and was hoping there was a way to set it to 20?
Re: custom bytes per row
Post by Maël » 23 Mar 2017 15:00
There are two ways:
  • Click on the menu View then "Bytes per row"
  • Set a value on the combobox that shows 16 per default, and change the value as you wish
    • You don't need to just pick from the list of default values, it's an edit box, too, so you can enter any value you like
If you want to change it permanently, and not just for the current window, go to Options and select the View tab.
