Not a bug: HxD 2.0.0.0 Incorrectly shows the data in the "Data inspector"
Niknik
Post by Niknik »
Japanese characters in the "data inspector" are displayed with an error. The output characters in line " WideChar/char16_t" do not match the table.
Re: HxD 2.0.0.0 Incorrectly shows the data in the "Data inspector"
Do you have an example?
I tried it successfully with the following byte sequence "73 5E EE 4E 0D 54 2C 00 20 00 72 30 89 30 4C 30 6A 30", which corresponds to"平仮名, ひらがな" assuming UTF-16 little endian encoding.
For this example it converts correctly. That is, "73 5E" is shown as WideChar "平" in the datainspector, "EE 4E" as "仮, "0D 54" as "名", etc.
Niknik
Post by Niknik »
I'm sorry, I was wrong.
