Fixed: Display of last line corrupted
Homer
Post by Homer »
HxD Version 2.0.0.0 (x86-64)
The last line (03359616) with correct data (6E024000):
After scrolling up and down with the mouse wheel the data in the last line has changed its display (DF050000) but not its content - see data inspector:
The wrong data from the last line can be found on the first page (line 00001248):
Re: Display of last line corrupted
I have found a similar bug that occurs when you resize the window and it will display the start of the file instead.
I couldn't reproduce it with the wheel scrolling, but the reason should be the same (it was a caching bug).
Could you please confirm that you can still reproduce the bug on the version of HxD you have, then see if this download fixes it?
https://mh-nexus.de/downloads/HxDSetup2.zip
Homer
Post by Homer »
Maël wrote: 28 Oct 2017 10:19Could you please confirm that you can still reproduce the bug on the version of HxD you have, [...]
Confirmed.
Maël wrote: 28 Oct 2017 10:19[...] see if this download fixes it?
Confirmed.
