Fixed: Split files with index
pTd
Post by pTd »
The file splitting tool adds an index to the end of each split file, but possibly due to me having extensions always visible it appears after the file extension, eg file.txt1, file.txt2, etc.
Is this intended behaviour? It would only be useful to me if the extensions are preserved and just the filename indexed.
Re: Split files with index
