Fixed: "Assertion Disordered"
CLK
Post by CLK »
I was comparing two files (same size of 71E4043B, presumably same, exact files) and pressed cancel, and the application does stop the process, but a dialog appears saying
HxD
Assertion fehlges (D:\Quellen\Neu\Hexeditor\Compare.pas, line 167)
OK
I can re-create this bug multiple times. Not a big deal but figured I'd might as well post it here in case it's something bigger.
Thanks for the great utility!
Re: "Assertion Disordered"
Thanks for reporting. I fixed it in the development version.
Fixed in 2.0 RC (since it was fixed in the development version already).
Download: https://mh-nexus.de/downloads/HxDSetup.zip
