Fixed: Status bar: Offset can be incorrect under some conditions
Surveyor
Post by Surveyor »
Maël,
When selecting a block, you can use the mouse or the keyboard (hold Shift down, use Home, End, left, right, up, down, etc.). Mouse selection is fine (forward and backward) and keyboard selection is fine in the forward direction. BUT, if you select a block with the keyboard in the backward direction (high offset to lower offset), the first change is not registered in the Status bar - Offset panel. Subsequent movements (backwards) are updated, but the Offset panel is ALWAYS 1 step behind! The result is that when the block is selected, the Offset and Block panels do NOT agree as to the offset of the start of the block (Block: correct, Offset: WRONG!).
Great little hex editor! I'm just "getting my feet wet", but I am learning some of the fine points.
- Surveyor (aka Allen)
Re: Status bar: Offset can be incorrect under some conditions
Fixed in the newest release:
Confirmation that it works as expected for you, too, would be appreciated.
